laminar two-phase flow, moving mesh and fluid structure interaction
I was wondering if it is possible to use the laminar two-phase flow, moving mesh method in conjunction with the fluid structure interaction interface to track the interface of two fluids and deformation of the structure?
Or can I only use the phase field or level set approach to track the fluid interface when coupled with FSI?
Thank you
0 Replies Last Post 14 juil. 2021, 16:05 UTC−4
Hello Elizabeth Dimbath
