Moving Mesh, CFD and automatic remeshing
Posted 8 juin 2012, 07:54 UTC−4 Computational Fluid Dynamics (CFD), Mesh Version 4.2a 1 Reply
Hi all,
again.
I am simulating a moving plate, subject to shear stress, inside a pipe, much like a rigid flag subject to wind (in 2D it is a small rectangle bar).
As of now, I am currently using Moving Mesh and the Laminar Flow module. And a Global Equation (as per Ivar suggestion) in the Laminar Flow module to get the total force.
I have prescribed Mesh displacement to move the plate, and no slip at the plate boundaries, but the wake appears to be filled with fluid with zero velocity, and I get inverted elements upon simulating for a bit.
Anything obvious I am missing? Shouldn't 'no slip' from Laminar Flow and the mesh smoothing be enough?
Concerning the inverted elements: I am trying to set a stop condition (tick automatic remeshing at the solver) so that it remeshes when mod1.ale.relVolMin < "something"
I tried with something = 0.9 or 0.5 and both give me an error. The solver gets to a certain point and the simulations ends with:
- Feature: Automatic Remeshing (sol1/null/t1/arDef)
- Error: Nonlinear solver did not converge.
What am I missing? Shouldn't it just remesh and then keep on solving? Does the solver know enough to use the new mesh?
Thank you for your time
again.
1 Reply Last Post 9 juin 2012, 05:19 UTC−4
