Geometry swelling and shrinking based on external and interal concentrations
Hey, I'm trying to model a human cell shrinking and swell with regards to extracellular and intracellular solute concentration. I've tried using a parametric curve, but it returns unknown variable mod1.c for one of my concentration variables. I've made sure that the variables are defined, but this problem persists. Has anyone else tried this. I'll attach my file to this.
Thank you
2 Replies Last Post 9 juin 2012, 20:00 UTC−4
Posted: 1 decade ago 8 juin 2012, 04:03 UTC−4
you cannot use variables to drive a geometry (at least not in v4.2a) you can only use Parameters and a Parametric sweep solver to modify the geometry.
However you should consider using the Deformed Geometry DG "physics" under Mathematics Deformed mesh
Check your doc, and the model library examples
Hi you cannot use variables to drive a geometry (at least not in v4.2a) you can only use Parameters and a Parametric sweep solver to modify the geometry. However you should consider using the Deformed Geometry DG "physics" under Mathematics Deformed mesh Check your doc, and the model library examples -- Good luck Ivar
Posted: 1 decade ago 9 juin 2012, 20:00 UTC−4
Hey, I have tried the deformed geometry physics, but it does not allow me to chose the boundaries that i want to move. Also, I can't find a deformed geometry physics example in comsol. I you know what it is under i would appreciate it.
The model is attached again this time with as far as i could get with the DG physics
Hey, I have tried the deformed geometry physics, but it does not allow me to chose the boundaries that i want to move. Also, I can't find a deformed geometry physics example in comsol. I you know what it is under i would appreciate it. The model is attached again this time with as far as i could get with the DG physics
