creating new geometry for a geometry object
Hi all,
I am trying to pick out one piece of my original geometry and do some analysis on it. I think this would be easiest if I simply do an intersection operation and set this to a new geometry geom2 to do the analysis. I have been trying to do this in livelink for matlab but the only command I can think of using is:
% initialise geometry
geom1=model.geom.create('geom1',2);
geom2=model.geom.create('geom2',2);
%create geom1
%create intersection
model.geom('geom1').feature(geomtag).set('size','width,height');
co1=model.geom('geom1').feature.create('co1', 'Compose');
co1.selection('input').object('geom1');
co1.selection('input').set({'i1' 'testr'});
co1.set('formula','i1*testr');
geom2=co1;
%build all
model.geom('geom1').runAll;
model.geom('geom2').runAll;
I can't seem to get this to work. It runs with no errors and co1 is created but geom2 is empty. I have also
tried this variant which I thought might import the object from geom1 to geom2.
co1=model.geom('geom2').feature.create('co1', 'Compose');
but this outputs an error I don't understand. any help or a sugestion of another approach would be greatly appreciated.
Jonathan
1 Reply Last Post 29 août 2012, 09:50 UTC−4
Hello Jonathan Lake
Posted: 1 decade ago 29 août 2012, 09:50 UTC−4
Why not copy the geometry feature within your new 'geom2'? So just do a command like:
model.geom('geom2').feature.copy('tag1','geom1/tag1');
Then you can extrude and do all the operations. Also, remember when you copy over a feature from one geometry to another that uses another feature for an input it loses that input.
Why not copy the geometry feature within your new 'geom2'? So just do a command like: model.geom('geom2').feature.copy('tag1','geom1/tag1'); Then you can extrude and do all the operations. Also, remember when you copy over a feature from one geometry to another that uses another feature for an input it loses that input.
