CFD model of a stripping column in gas sweetening process
Posted 4 juil. 2021, 00:48 UTC−4 Fluid & Heat, Corrosion Processes, Computational Fluid Dynamics (CFD) Version 4.3a 0 Replies
I'm assigned to a project where I need to develop a CFD model of a stripper used in sour gas removal process via amines. With this, I'll investigate the source of corrosion. As a first insight, I believe I'll need velocity and pressure (temperature) profiles to correlate them to the corrosion rate. So my question is:** Is there any template for the CFD modelling of a column that I can use and get an idea from it?**
Views of the experts in this field are highly appreciated!
Hello Sohrab Askarli
