diffusion with a specialized boundary condition
Hi! I think my question is fairly straightforward, I just can't seem to figure it out...
I am trying to model diffusion of particles from one region into another region. The two regions are separated by a boundary with two characteristics:
1) flux is fixed at zero in one direction
2) in the other direction, flux is defined in terms of a transmission probability. (for a given incoming particle, the particle has a specified probability of passing through, and a specified probability of bouncing back)
I understand how to describe the physics of each each region using a coefficient form PDE. Is a boundary such as described above a type of "weak constraint"? It seems like a simple situation, but I haven't yet found a way to implement this....
Thanks a lot for your help!
-scott
3 Replies Last Post 15 juin 2012, 11:40 UTC−4
Posted: 1 decade ago 14 juin 2012, 17:26 UTC−4
Hmm... this should be pretty simple, but I still haven't figured it out... can anyone help? How can I set up a boundary that allows diffusion in only one direction? Thanks a lot!
-scott
Hmm... this should be pretty simple, but I still haven't figured it out... can anyone help? How can I set up a boundary that allows diffusion in only one direction? Thanks a lot! -scott
Posted: 1 decade ago 15 juin 2012, 00:59 UTC−4
often 1 line of text can translate into a few pages of math ;)
Unfortunately I cannot help like that, but have you tried to ask "support", here we are only users ...
Hi often 1 line of text can translate into a few pages of math ;) Unfortunately I cannot help like that, but have you tried to ask "support", here we are only users ... -- Good luck Ivar
Posted: 1 decade ago 15 juin 2012, 11:40 UTC−4
-scott
The diffusion coefficient can be set to vector. So just change the value of the direction that you dont want the diffusion occurs to be zero 0.
Cheers,
Dao
[QUOTE] Hmm... this should be pretty simple, but I still haven't figured it out... can anyone help? How can I set up a boundary that allows diffusion in only one direction? Thanks a lot! -scott [/QUOTE] The diffusion coefficient can be set to vector. So just change the value of the direction that you dont want the diffusion occurs to be zero 0. Cheers, Dao
