Piecewise function as material variable
I've implemented a piecewise function and now I want to use it as a dynamic viscosity for my model, but the program doesnt use it at all. I've plotted the function I made and it worked well, but I cant apply it as a function for the viscosity. Any ideas?
Thx in advance!
P.S. I've attached my model.
4 Replies Last Post 1 juin 2012, 15:15 UTC−4
Posted: 1 decade ago 31 mai 2012, 16:29 UTC−4
replace your usage of the mua[Pa*s] by mua(T). You need to tell COMSOL to use the temperature explicitely, in the analytical function definition the argument nameis a local "dummy" name, not linked to the true variable names.
Then as you have already defined the units in the analytical functions, you do not need to add tem again, else you will "suare" the units
Hi replace your usage of the mua[Pa*s] by mua(T). You need to tell COMSOL to use the temperature explicitely, in the analytical function definition the argument nameis a local "dummy" name, not linked to the true variable names. Then as you have already defined the units in the analytical functions, you do not need to add tem again, else you will "suare" the units -- Good luck Ivar
Posted: 1 decade ago 1 juin 2012, 05:22 UTC−4
Hello Ivar,
I´ve subsituted mua Pa*s with mua (T) but it still doesnt work. Am I missing something?
Thx for your response!
Hello Ivar, I´ve subsituted mua Pa*s with mua (T) but it still doesnt work. Am I missing something? Thx for your response!
Posted: 1 decade ago 1 juin 2012, 06:07 UTC−4
if you look up a few materials there are several with T or p dependance, compare the COSMOl way and yours
Hi if you look up a few materials there are several with T or p dependance, compare the COSMOl way and yours -- Good luck Ivar
Posted: 1 decade ago 1 juin 2012, 15:15 UTC−4
you need finally to write
mua(T[1/K])
obviosly in v4.2a everything is not yet up for the units in operators. with this it runs without warnings, but I cannot tell if your results are correct, as I'm not really understanding what you are doing ;)
Ony suggestion: consider smoothened step or rect function for your transitions, as "dirac type too steep transisitons tend to give solver issues
Hi you need finally to write mua(T[1/K]) obviosly in v4.2a everything is not yet up for the units in operators. with this it runs without warnings, but I cannot tell if your results are correct, as I'm not really understanding what you are doing ;) Ony suggestion: consider smoothened step or rect function for your transitions, as "dirac type too steep transisitons tend to give solver issues -- Good luck Ivar
