Quick AC/DC Rotational Machinery Question
Posted 28 mai 2012, 00:13 UTC−4 Low-Frequency Electromagnetics, Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 4.2a 1 Reply
Hello everyone
I am working on understanding how to use the rotary machinery physics in the AC/DC module using the 2d generator in the model library. I have changed the rotors to just be iron and made the coils have different phases, using Imax=sqrt(2)*10 [A] and changing the current in the multi-turn coil domain to Imax*exp(i*0) for one phase, Imax*exp(i*(2*pi)/3) for second phase and Imax*exp(i*(4*pi)/3) for the third phase.
I then run the simulation but it does not work. If I change the coils to an ampere's law with cylindrical coordinates with a radial remenent magnetic field and run the simulation then the rotor turns and it works. But if I use the different phases it errors out saying it has done too many steps. It seems I cannot have a changing phase in the stator while the rotor is rotating, which is what I want to do.
Does anyone have any ideas as to how I can make the stator coils have 3-phases while the rotor, with no magnetic fields just iron, rotates inside the stator?
Thanks.
Stephen
Thanks.
Stephen
1 Reply Last Post 28 mai 2012, 05:23 UTC−4
