triangularly distributed load
I wonder if it is possible to model a triangularly distributed load on a cantilever beam .
Moreover, is it possible to model a load varying with the function of the coordinate ?
1 Reply Last Post 27 mai 2012, 06:06 UTC−4
Posted: 1 decade ago 27 mai 2012, 06:06 UTC−4
normally you apply a boundary load on a predefined boundary, the easiest, but if you select a large boundary and define a load as a function of the coordinates you can mathematically limit the load to a subregion of your boundary.
I do belieev your matrices tend to b more tough to inverse, but with todays computers it mostly works quite OK
Hi normally you apply a boundary load on a predefined boundary, the easiest, but if you select a large boundary and define a load as a function of the coordinates you can mathematically limit the load to a subregion of your boundary. I do belieev your matrices tend to b more tough to inverse, but with todays computers it mostly works quite OK -- Good luck Ivar
