Axisymmetric Integration is giving wrong results
Hello guys
I ran into an issue while computing an integral (intop1) in an axisymmetric simulation, I have a variable which is pressure (p) and I need to integrate it over a body surface, when integral is calculated it's yielding force in r-direction which is not correct at all. does anyone have any idea why this happens? is it a bug?
Best, William
1 Reply Last Post 5 mai 2021, 15:21 UTC−4
Posted: 4 years ago 5 mai 2021, 15:21 UTC−4
It is probably not a bug. You probably have an error somewhere in either the way you set up the model or performed the force computation. I suggest you post your model to the forum.
It is *probably* not a bug. You *probably* have an error somewhere in either the way you set up the model or performed the force computation. I suggest you post your model to the forum.
