Multiple phases on a single 1D plot
Posted 20 avr. 2021, 15:05 UTC−4 RF & Microwave Engineering Version 5.1 0 Replies
In the Electromagnetic Frequency Domain I know how to plot a field component, say emw.Ex, versus distance (say x) on a 1D plot for a specific phase angle theta by plotting real(emw.Ex * exp(i * theta)) or by using "Solution at phase". It's a single curve. I also know how to create multiple 1D plots under a 1D plot group and show several curves on the same axes, each with a different phase.
But it's tedious to create all those 1D plots if I want to see a combination of, say, 360 different phases. Is there a way to plot this collection as multiple curves superimposed on the same 1D group, with a theta parameter varying for each?
I tried putting in a range() in the "Solution at phase" setting, no luck.
So the question is, how to get a Parametric Sweep "like" behavior versus phase angle so I can make the 1D plots of real(emw.Ex * exp(i * theta)) on the same axes for many different thetas, like I can for ordinary Parametric Sweep parameters.
It's probably simple, I'm just not seeing it.
-- C
Hello Chris Nadovich
