What is P_chms?
I noticed this variable in some equations auto-generated when importing parameters from the Chemical Reaction Engineering Library. If I have an application mode that has pressure as a dependent variable (say General Laminar Flow) are "p" and "P_chms" the same thing?
1 Reply Last Post 16 mai 2012, 11:04 UTC−4
Posted: 1 decade ago 16 mai 2012, 11:04 UTC−4
3.5 is too old, sorry, but you can try to look up the COMSOL variables and see what is described therein, It's discussed already on the FORUM but quite some time ago ;)
Hi 3.5 is too old, sorry, but you can try to look up the COMSOL variables and see what is described therein, It's discussed already on the FORUM but quite some time ago ;) -- Good luck Ivar
