Running Comsol generated .m file
Dear Comsol users
I'm just beginning with using Comsol and I received an .m file which apparently was generated by Comsol 3.4. I'm supposed to execute this file to produce the plot which is defined therein. How do I go about to do so? I have a trial licence of Comsol Multiphysics 4.2a available. Or should I actually be executing this file with Matlab? I attached the file.
Thanks for any support on this.
Martin
3 Replies Last Post 12 mai 2012, 14:33 UTC−4
Posted: 1 decade ago 12 mai 2012, 11:50 UTC−4
COMSOL V4 can only read 3.5a files I believe, sou you need to get your 3.4 translated to 3.5a by someone, or by COMSOL support (unfortunately I do not have 3.5a up running anymore ;(
Hi COMSOL V4 can only read 3.5a files I believe, sou you need to get your 3.4 translated to 3.5a by someone, or by COMSOL support (unfortunately I do not have 3.5a up running anymore ;( -- Good luck Ivar
Posted: 1 decade ago 12 mai 2012, 13:09 UTC−4
Thanks for the answer. I'll be trying to fix this.
Do you know of any overview/comparison of changes from 3.4/3.5 to 4.0, such that I could identify how I need to make the adjustments?
Thanks again.
Martin
Thanks for the answer. I'll be trying to fix this. Do you know of any overview/comparison of changes from 3.4/3.5 to 4.0, such that I could identify how I need to make the adjustments? Thanks again. Martin
Posted: 1 decade ago 12 mai 2012, 14:33 UTC−4
for 3.4 to 3.5a I do not believe there were that many, you need to find the release notes, but from 3.5 to 4, about everything. That is why I always remake my models from scratch in v4, at most I import a 3.5a and then cut and past long formulas if I have any, but all variable names (those of COMSOL) ave changed a little so it's a major task
Hi for 3.4 to 3.5a I do not believe there were that many, you need to find the release notes, but from 3.5 to 4, about everything. That is why I always remake my models from scratch in v4, at most I import a 3.5a and then cut and past long formulas if I have any, but all variable names (those of COMSOL) ave changed a little so it's a major task -- Good luck Ivar
