Compression of metallic sphere
Hello :) I'm a beginner in Comsol. I want to simulate the compression of a spherical metallic particle (in temperature above its melting temperature) between two plates that are getting closer to each other. I already have created geometry and moving parts. The problem with physics is left: - What should I put in definition (except of two contact pairs between each of the plates and sphere)? - Is Comsol will understand the changing from solid to liquid state of material?
Thank you in advance :)
0 Replies Last Post 20 mars 2021, 13:09 UTC−4
Hello Yaroslav Harkavyi
