using previous COMSOL solution as initial value for another solution
Abhishek Yewale Chemical Engineering
Hi, I am performing parametric sweep for finding solution. The study is time dependent. I have one paramter such as temperature whose value is 333, 343, 353 (K) and another parameter is time whose value is 1, 2, 3 (hours). I want to obtain value of dependent variable u in following manner for 1 hr at 333K (total of 1 hour) for 1 hr at 333K and 1 hr at 343 K. (total of 2 hours) for 1 hr at 333K,1 hr at 343 K and 1 hr at 353 K. (total of 3 hours) So basically I want to have value of u at each temp for 1 hr. And the initial condition at another temp should be the final value of previous temp.
Thank you in advance. Looking forward for your help.
1 Reply Last Post 5 mars 2021, 04:56 UTC−5
Posted: 4 years ago 5 mars 2021, 04:56 UTC−5
there are so many characters that confuse me. Can you tell me more specifically to help you?
there are so many characters that confuse me. Can you tell me more specifically to help you[?](http://comsol.it/forum)
