Visualization of the filling process of a volume by air
How I can visualize the filling process?
I'm gonna use the laminar flow (spf) package and want to simulate the filling procedure of a simple geometry for example a tube system with one inlet and one outlet. Now the time dependent problem is solved and I can visualize the velocity field, pressure field and so on. Is there any possibillity to show the time dependent state of the exchanged air? May be there is a model in the library but i didn't found any fitting problem.
Thanks for help, regards
Tristan
2 Replies Last Post 2 mai 2012, 06:49 UTC−4
Posted: 1 decade ago 27 avr. 2012, 07:36 UTC−4
isnt that then some particle flowe visualisation you need ?
if you have 2 fluids, then you can always plot i.e. the density and see the two (if they differ in density) versus the time
Or have I missed something ?
Hi isnt that then some particle flowe visualisation you need ? if you have 2 fluids, then you can always plot i.e. the density and see the two (if they differ in density) versus the time Or have I missed something ? -- Good luck Ivar
Posted: 1 decade ago 2 mai 2012, 06:49 UTC−4
Hello
thanks for answering my posting!
the visiualisation of the particle flowe would be the next step in my work. First I want to understand the exchange of the air / fluid.
But how I can implement the second / incoming fluid in comsol. Then it would be a easy one to seperate them at the post processing.
may I didn't capture the concept... ;-)
Tristan
Hello thanks for answering my posting! the visiualisation of the particle flowe would be the next step in my work. First I want to understand the exchange of the air / fluid. But how I can implement the second / incoming fluid in comsol. Then it would be a easy one to seperate them at the post processing. may I didn't capture the concept... ;-) Tristan
