Damped Cantilever Vibration
hey all, I am trying to model a simple cantilever beam (50u x 5u x 5u). I am applying an edge load on end and have the face on the opposite end a fixed constraint. I want to see a transient analysis as this beam oscillates and eventually stops due to damping factors. The best form of output i would like to see is a displacement vs time graph that shows that the displacement is zero at a certain time (i would like to control this time with the damp coeff)
I have tried analyzing it in both time-domain and frequency domain modes, but in both cases all i'm getting is a single graphic displaying the displacement at the end of time, which even with a damping alpha has some displacement.
thanks for your help!
1 Reply Last Post 24 avr. 2012, 14:46 UTC−4
Posted: 1 decade ago 24 avr. 2012, 14:46 UTC−4
what are you using as load ? a gaussian or step type pulse for the time domain and a constant load for the frequency scan ?
At least that is what i would try
Hi what are you using as load ? a gaussian or step type pulse for the time domain and a constant load for the frequency scan ? At least that is what i would try -- Good luck Ivar
