how to drae a blood vessel
hi'
i want to simulate arterial blood flow.
I mean, I want to create two pipes one inside the other which one will resemble other blood flow and mechanical properties of the artery.
How do I build these pipes (geometrically)? Is there a way to build a hollow tube?
Thank you
hagar
1 Reply Last Post 20 juil. 2014, 17:32 UTC−4
Hello Hagar Bernad
Posted: 1 decade ago 20 juil. 2014, 17:32 UTC−4
You might have figured this out already, but you can do a right mouse click on "Geometry" and select "cylinder." Once you model the first cylinder, you can then place a second cylinder of smaller diameter on the same cartesian axis coordinates as the first cylinder.
If you make the outside cylinder shorter than the internal cylinder, you can probably design two cones, one for each end, that closes the gap between the two cylinders.
With that said, I am not sure "why" you "might" want a cylinder within a cylinder to model flow. If you are trying to develop a "thickness," in order to model the muscle layers of an artery, you can probably adjust the thickness of the cylinder and then attempt to apply a specific material type with properties. I have not done this though so I cannot say it is possible.
Hello, You might have figured this out already, but you can do a right mouse click on "Geometry" and select "cylinder." Once you model the first cylinder, you can then place a second cylinder of smaller diameter on the same cartesian axis coordinates as the first cylinder. If you make the outside cylinder shorter than the internal cylinder, you can probably design two cones, one for each end, that closes the gap between the two cylinders. With that said, I am not sure "why" you "might" want a cylinder within a cylinder to model flow. If you are trying to develop a "thickness," in order to model the muscle layers of an artery, you can probably adjust the thickness of the cylinder and then attempt to apply a specific material type with properties. I have not done this though so I cannot say it is possible.
