Daniel Ahlman
COMSOL Employee
4 years ago
16 févr. 2021, 08:01 UTC−5
Hi Scott,
The Transport of Diluted Species interface defines a vector variable tds.mflux_c for the flux due to migration of the species "c". In a cartesian model (1D, 2D, 3D) the vector components are:
tds.mflux_cx
tds.mflux_cy
tds.mflux_cz
You can evaluate the magnitude of the vector by plottting:
sqrt(tds.mflux_cx^2+tds.mflux_cy^2+tds.mflux_cz^2)
Unfortunatley there is no pre-defined post processing variable for the magnitude of the flux due to migration in the Transport in Diluted Species interface. We will add it for the next version.
Note however that this is the magnitude of the vector (independent of the direction). If you want the flux across a boundary, you should use the normal flux variable (tds.nmflux_c) which is defined using a dot product
tds.nmflux_c =(tds.mflux_cx, tds.mflux_cy, tds.mfluxcz)
(nx, ny, nz) =
tds.mfluxcx*nx+tds.mfluxcy*ny+tds.mfluxcz*nz
where (nx, ny, nz) is the boundary normal.
To look for variables (which may not be available in the postprocessing variables list) you can enable the Equation View for all nodes and search among all variables available in the following manner:
- Click the Show More Options button in the Model Builder window (the eye icon)
- In the pop-up window displayed, click to enable Equation View
- Use CTRL+f to open the Find window
- Type for example "mflux" in the input field and click the Find button
- => A Find Results window is opened with all hits (usually located under the Graphics window)
- The entries in the table in the Find Results window can be double-clicked. This will show the corresponding variable definition in the Setting window.
Hi Scott,
tds.mflux_cx
tds.mflux_cy
tds.mflux_cz
tds.nmflux_c =(tds.mflux_cx, tds.mflux_cy, tds.mfluxcz) \cdot (nx, ny, nz) =
tds.mfluxcx\*nx+tds.mfluxcy\*ny+tds.mfluxcz\*nz
* Click the Show More Options button in the Model Builder window (the eye icon)
* In the pop-up window displayed, click to enable Equation View
* Use CTRL+f to open the Find window
* Type for example "mflux" in the input field and click the Find button
* => A Find Results window is opened with all hits (usually located under the Graphics window)
* The entries in the table in the Find Results window can be double-clicked. This will show the corresponding variable definition in the Setting window.
