Frequency domain - mechanical
Posted 15 avr. 2012, 05:21 UTC−4 Structural Mechanics Version 4.4 10 Replies
I am an electronics student and am trying to simulate the mechanics of a square plate.
My plate has the 4 side faces fixed and a uniform distributed load on one of the larger faces.
The stress and displacement are close to calculated values - hence I can justify that my understanding is verified by the simulation.
I tried to find the eigen frequencies. My query - is the solution given by comsol for eigen frequency = omega (= 2.pi.f) or is it = "f"?
I tried the frequency domain simulation. Here, the frequency that I enter are omega (= 2.pi.f) or is it "f"?
Please recommend me books where, from formulae, I can calculate the resonant frequency and compare with the simulated results. I tried Timoshenko - strength of materials -2, but did not get the frequency.
Thanks in advance.
eifgenfrequency is in Hz or "f" eigenvalue in omega or rad/s. A frequency domain solving you should give the frequency in Hz. Check the model library and do some of the exercices therein (do not forget to update your model library first)
PS: try to get a newer version, 4.0 was a "first out" of an important change in the software, it was not very stable
I am trying to get a frequency response using COMSOL 4.4 from a clamp-free shaft cantilever. The problem is that COMSOL solve it for a limited frequency ranges but not for my desired range. Can any one tell me what's wrong? I attached my simulation with the freq range that is working but I want to run it in range of 1-1.5 KHz and it doesn't work.
Regards, Mesut
1. Find the resonance frequency from Eigen frequency (that option is available)
2. Run frequency response at all frequencies except close to the Eigen frequency
3. The peaking in response near the resonant frequency should suffice to show the overall trend in freq resp.
4. Remember, theory and simulation are different from practical. Fabrication process variations can really throw up different results. Use the simulation only as a confidence building measure.10% error or more is acceptable as long as your answers are within one order of variation.
Best wishes
As long as there is damping in your model (and there always is in real life) there is no problem in solving also at the resonance frequency. Determining an appropriate damping for a certain system can be difficult, though.
Henrik
If you get a message about non-convergence in the frequency response analysis even when having appropriate damping, please submit the model to support.
Henrik
Regards, Mesut
The problem here is that the 'dynamical stiffness matrix' becomes extremely ill-conditioned. This kind of geometry should preferably be treated using beam elements. Using solids, you would need even more elements to arrive at an accurate solution.
But if you want to force this problem to be solved, you much switch of the check of the conditioning in the linear equation solver: In the 'Direct' node in the solver sequence, locate the 'Error' section. Set 'Check error estimate' to 'No'.
Henrik
Does anyone know How can I get a displacement PSD (Power Spectrum Density) from a frequency response simulation in COMSOL? Does it matter if I use base motion or force excitation?
Regards, Masoud
Suggested Content
- FORUM different results of simulating mechanical resonant frequency
- FORUM collision in mechanical domain
- BLOG New Piezoelectric Modeling Interface in COMSOL 5.0
- KNOWLEDGE BASE Solving electromagnetic heating models with high-frequency loads
- BLOG How to Create Outstanding Sound Performance in Vehicles
