Frequency Domain analysis of 3D coil with permanent magnet
Hi all,
I have a 3D homogenized coil around a permanent magnet (2.5kA/m, z-direction) where an alternating current of 2.5kHz is applied. I am performing a Frequency Domain study to examine the AC effect of the combined magnetic field. However, during this study it turned out that also the magnetization of the permanent magnet has a harmonic shape instead of a constant value. Is there a way to keep this magnetization constant for this type of study or do I need to switch to a Time Domain study?
3 Replies Last Post 27 janv. 2021, 14:40 UTC−5
Posted: 5 years ago 24 janv. 2021, 04:43 UTC−5
Paul,
in case the AC signal is small it can be treated as a perturbation in a small signal analysis. If it is not small the time domain is the way to go.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Paul, in case the AC signal is small it can be treated as a perturbation in a small signal analysis. If it is not small the time domain is the way to go. Cheers Edgar
Posted: 5 years ago 27 janv. 2021, 08:45 UTC−5
Edgar,
Thanks for the quick response. The stationary magnetic field strength is 230mT and the coil's AC generates an additional 3mT field. I have used a perturbation study in this case. I assume that it is small enough?
Best regards, Paul
Edgar, Thanks for the quick response. The stationary magnetic field strength is 230mT and the coil's AC generates an additional 3mT field. I have used a perturbation study in this case. I assume that it is small enough? Best regards, Paul
Posted: 5 years ago 27 janv. 2021, 14:40 UTC−5
Yes, that should be good enough.
Edgar J. Kaiser
www.emphys.com
