line graph of surface integral
My model is a cylinder (3D) axis is in z direction.
I can get a surface integral of a variable (eg volume force) in any xy plane.
I now wish to display on a line graph, the variation of this xy integral in the z direction.
Is this possible without having to manually run a series of surface integrals at different z values?
thanks
David
3 Replies Last Post 8 avr. 2013, 13:49 UTC−4
Posted: 1 decade ago 5 avr. 2012, 09:58 UTC−4
If you can compute it, you can have it populate a table. From the table you can plot it.
Posted: 1 decade ago 5 avr. 2012, 11:07 UTC−4
I believe you can also use an integration with a mapping onto your Z line axis and then you use a line plot on thatmapped integrated value
Hi I believe you can also use an integration with a mapping onto your Z line axis and then you use a line plot on thatmapped integrated value -- Good luck Ivar
Posted: 1 decade ago 8 avr. 2013, 13:49 UTC−4
Dear Ivar,
Is the mapping you mentioned a model coupling? In David's example, how would you implement the method you describe?
Thank you,
Adam Parrott
Dear Ivar, Is the mapping you mentioned a model coupling? In David's example, how would you implement the method you describe? Thank you, Adam Parrott
