How to store multiple data in one dat file (.txt, etc..)??
Posted 3 avr. 2012, 04:47 UTC−4 0 Replies
I don't know if comsol has this option, but I'm integrating my plots varying a single parameter, then I have multiple results, one for each run.
TO be more clear, I run my system, then export the integration (by doing the typical add to export to the integral option), I get the result for this run, then I re-run my system and the only opion I have is again to export this second integration but it appears in a new data file so in the end I have two dat (.txt. etc...) files with one single result each one.
I would like to have both results in one single file to be able to plot them directly. Is this possible or I have to use a third party software to put the files together or copy paste my results in a new dat file... is quite annoying if I have not two but a lot of data.
cordially,
Christian
Hello Christian Ortiz
