Rectangle function
Posted 2 avr. 2012, 22:04 UTC−4 Heat Transfer & Phase Change 1 Reply
Good afternoon.
I am making a model using heat transfer in solids module, where I have a bar divided with some finite elements.
The model is 2D, and over from one element, I have heat flux, and on the next six elements,
I have no convective cooling. The other elements have convective cooling.
The problem is, when the heat flux element get a temperature of 350 K, I need to change the heat flux
to the next element, besides change elements without convective cooling too (the same configuration at the
begining of simulation).
One way that I found how to do this is by using rectangular functions, where in a determined time, I change the elements. But the result with this metodology is very weak, because the temperature never stops with 350 K.
So, the question is: can I work with rectangular function using temperature, instead of time?
I tried to use analytics functions, but I cant know how is the temperature profile with the time.
There is another way to do this?
Best regards
Gabriel Tortola Flores Vieira
Ps: sorry about my english. I am from Brazil, and I am not a fluent speaker.
Best regards
1 Reply Last Post 3 avr. 2012, 03:10 UTC−4
