Best solution with low memory used
Posted 25 mars 2012, 03:05 UTC−4 Fluid & Heat, Studies & Solvers 0 Replies
I have problem with my model while its run suddenly will be failed because of the memory not enough. i want to ask if we can chose another solution type of solution(in general i use Direct spooles) to reduce the using of memory or any other idea to reduce of its.
Best Regard
Hello Hyder Balla
