Using "Stored Solution" in another Study
In my model, I have two Studies. In the first study, I Store the solution to use it as the initial condition for the 2nd Study. I was wondering if cross-Study use of "Store Solution" is valid, or it is only valid within a single Study.
Jessica
1 Reply Last Post 21 mars 2012, 13:44 UTC−4
Posted: 1 decade ago 21 mars 2012, 13:44 UTC−4
check the tag names ans the Data set, I believe its' the Data set DB that COMSOL uses to extract the desired initial condition for any further study, as with solution, you must precise which one, and at which time or parameter value, if applicable
Hi check the tag names ans the Data set, I believe its' the Data set DB that COMSOL uses to extract the desired initial condition for any further study, as with solution, you must precise which one, and at which time or parameter value, if applicable -- Good luck Ivar
