warning failed to render face '4'
Why would comsol fail to render a specific face?
2 Replies Last Post 20 mars 2012, 11:14 UTC−4
Posted: 1 decade ago 20 mars 2012, 04:30 UTC−4
I dont know which kind of file (*.stl or *.stp ...) do you use to import in COMSOL. Have you tried to verify that there is no "open edge" in your geometry before importing ?
I would like to know if you resolve your problem
Dinh
I dont know which kind of file (*.stl or *.stp ...) do you use to import in COMSOL. Have you tried to verify that there is no "open edge" in your geometry before importing ? I would like to know if you resolve your problem Regards, Dinh
Posted: 1 decade ago 20 mars 2012, 11:14 UTC−4
I created the geometry in comsol. I have a feeling something strange is going on, though. The problem vanishes when I disable a somewhat complicated 3D shape I have, even though they don't touch. The shape consists of an open parametric curve closed with an open polygonal path, where that union closed curve is converted to a solid, and revolved around some axis to 3D-ize it.
