Specification for a work station to run 3D simulation
Dear COMSOL users, I would like to get a work station for running my COMSOL Simulation (Both 3D and 2D). I need some assistance in the specification of the machine. Can you Please tell me which type of work station could be most suitable for my work? Please specify everything clearly so that I can go for that easily. Thanks, and Regards Danish
3 Replies Last Post 15 oct. 2020, 09:08 UTC−4
Posted: 5 years ago 10 oct. 2020, 20:33 UTC−4
You will want to look at
https://www.comsol.com/system-requirements
How much you go beyond the minimum requirements depends on how big your problems are. Some 3D simulations run OK on a basic laptop.
You will want to look at https://www.comsol.com/system-requirements How much you go beyond the minimum requirements depends on how big your problems are. Some 3D simulations run OK on a basic laptop.
Posted: 5 years ago 12 oct. 2020, 08:37 UTC−4
Hello Danish,
In addition to the system requirements page, which only tells you about the minimum specifications, this page should help you spec out a new machine: Support Knowledge Base entry 866.
Jeff Hiller
Hello Danish, In addition to the system requirements page, which only tells you about the minimum specifications, this page should help you spec out a new machine: [Support Knowledge Base entry 866](https://www.comsol.com/support/knowledgebase/866). Best regards, Jeff
Posted: 5 years ago 15 oct. 2020, 09:08 UTC−4
Thanks Dave and Jeff for the information.
