Using previous solutions as defined values for a new simulation
Posted 16 mars 2012, 05:56 UTC−4 Fluid & Heat, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 3.5a 0 Replies
I just solved a stationnary problem that i called base flow.
In order to study an instability problem, i need to use the solution of the base flow because my equations depend on it.
The problem is that my base flow is spatial dependant.
So i would like to know if it is possible to define a "constant" that is différent for each element of the mesh.
Thank you for your answers
Hello Etienne Cartier
