How to Convert a 2D model Into 3d model
I want to know that how i can convert a 2D model into 3D model for simulation.
Vineet Bansal
Project Associate, NPMASS
Electronic Science Department
Kurukshetra University, Haryana
5 Replies Last Post 4 juin 2015, 17:19 UTC−4
Posted: 1 decade ago 15 mars 2012, 10:03 UTC−4
the only way I know is that one can do is to:
1) export your 2D and
2) import it into a new 3D model file in a 3D workplane, and then extrude or revolve from there
the rest of the mesh, materials and physics must be set up new in 3D (I often open 2 sessions and copy past the fomulas from one to the other, as these seldom change between 2D and 3D)
It is also possible to add a 2nd model in the current file, OK if the files are "small", but I prefere separate files
Hi the only way I know is that one can do is to: 1) export your 2D and 2) import it into a new 3D model file in a 3D workplane, and then extrude or revolve from there the rest of the mesh, materials and physics must be set up new in 3D (I often open 2 sessions and copy past the fomulas from one to the other, as these seldom change between 2D and 3D) It is also possible to add a 2nd model in the current file, OK if the files are "small", but I prefere separate files -- Good luck Ivar
Posted: 1 decade ago 8 mars 2013, 18:06 UTC−5
Dear Ivar,
I am using 4.2 version but I am not able to do what you said. I exported 2D Geometry (right click on geometry then selecting export to file) and I tried to import that to a 3D file by right click on geometry then selecting import. However I see this error: "Cannot import a 2D geometry into a 3D sequence."
I would be so thankful if you could let me know what the problem is.
Zahra
[QUOTE] Hi the only way I know is that one can do is to: 1) export your 2D and 2) import it into a new 3D model file in a 3D workplane, and then extrude or revolve from there the rest of the mesh, materials and physics must be set up new in 3D (I often open 2 sessions and copy past the fomulas from one to the other, as these seldom change between 2D and 3D) It is also possible to add a 2nd model in the current file, OK if the files are "small", but I prefere separate files -- Good luck Ivar [/QUOTE] Dear Ivar, I am using 4.2 version but I am not able to do what you said. I exported 2D Geometry (right click on geometry then selecting export to file) and I tried to import that to a 3D file by right click on geometry then selecting import. However I see this error: "Cannot import a 2D geometry into a 3D sequence." I would be so thankful if you could let me know what the problem is. Regards, Zahra
Posted: 1 decade ago 9 mars 2013, 04:23 UTC−5
the separation 2D 3D is quite strict in COMSOL geometries, but in 3D you can open a local workplane in 2D, import your 2D in there and then extrude or rotate to 3D, no ?
Hi the separation 2D 3D is quite strict in COMSOL geometries, but in 3D you can open a local workplane in 2D, import your 2D in there and then extrude or rotate to 3D, no ? -- Good luck Ivar
Posted: 1 decade ago 11 mars 2013, 11:16 UTC−4
Yes, Now it works. Thank you very much.
Zahra
Hi, Yes, Now it works. Thank you very much. Regards, Zahra
Posted: 10 years ago 4 juin 2015, 17:19 UTC−4
I'm using 4.4 I have a 2D version of an electromagnet coil (which is rectangular), now want to make it 3D i opened a new 3D file, created a work plane. When I revolve, I get a solid cylinder instead of the coil. What am I doing wrong?
Dj
Hi, I'm using 4.4 I have a 2D version of an electromagnet coil (which is rectangular), now want to make it 3D i opened a new 3D file, created a work plane. When I revolve, I get a solid cylinder instead of the coil. What am I doing wrong? Dj
