Dave Greve
Certified Consultant
4 years ago
30 sept. 2020, 16:13 UTC−4
They really should call them IMperfectly matched layers.
You should check the settings (wave velocity), the thickness, and the meshing (mapped mesh with ~5 elements preferred). And at least in emw there are some additional parameters that can be adjusted.
If it's critical set up a separate simulation to quantify the amount of reflected wave.
4 years ago
1 oct. 2020, 07:54 UTC−4
Updated:
4 years ago
1 oct. 2020, 08:31 UTC−4
Hi Dave,
I need to have a non-reflecting boundary in my thermoviscous acoustic simulation, but it seems this so-called "PML" is not working the way it should. in my simulation pml geometry is a rectangle surrounding a partcle and I want pml to absorb scattered wave off the particle (which are spherical-shaped waves) but it's not working. You think it might be due to the scatterd way angle to PML?
Kind regards
Hi Dave,
Kind regards
