time dependent analysis piezoacoustic transducer
Posted 14 mars 2012, 15:58 UTC−4 Version 4.0a 2 Replies
Hi, everyone and Ivar,
I am working on an example from COMSOL "Transient Gaussian explosion" (attached as: Transient model march14). As you see in the attached file which is with a 4.0a version of COMSOL which is what I only have, based on the example it has used a point source but i do not want to use a point source and I should have something like the piezoacoustic transducer example to have a source like a rectangle and not a point source to analyse with time dependent study and NOT frequency domain study which is so important.
So I wanted to ask if this is possible to do, using the Transient pressure Acoustics, and the Piezoelectric devices in COMSOL 4.0 as what i have in the attached (attached as: Transient model march14-with piezo) and how to do it since if you run my model although it has not errors but there is no presentation for the acoustic pressure results after simulation and it is all green :( .
I am waiting for your response.I appreciate it in advance for your great help to me. please let me know if you have any questions.
I deleted mesh to reduce the size of file, for the files the maximum mesh size should be set to h_max which is already defined.
Navid
Navid
2 Replies Last Post 14 mars 2012, 16:41 UTC−4
