Cut Line and Cut Point display
Posted 9 mars 2012, 11:22 UTC−5 Geometry, Results & Visualization Version 4.2a, Version 4.3 1 Reply
Good Day, As I set up Data Sets using Cut Lines and Cut Points in 2D models COMSOL provides visual assistance. These take the form of an X,Y Axis pair for the Cut Lines and a red spot for the Cut Points. Unfortunately the axis pair can obstruct the short cut line such that I cannot be sure of correct placement. Similarly the red spot is quite large and obstructs local geometry. (These models are MEMS devices and it is set to um.)
Are you aware of a way to either: Reduce the size, displace, or turn off these visual aids? I don't see them in the Preferences set.
Many Thanks for your advice.
1 Reply Last Post 13 mars 2012, 10:17 UTC−4
