Jeff Hiller
COMSOL Employee
4 years ago
17 août 2020, 14:34 UTC−4
Hi Garrett,
The presence of 2.5mm of nylon does not per se imply one boundary condition over another. Depending on what's happening 2.5mm away at that interface between nylon and whatever's further away there'll be a different temperature and temperature gradient where you are currently trying to set your BC.
A guess: If 2.5mm away you have an interface with air, you may well need to include that intermediary nylon region in your computational domain and set a convective cooling condition on its periphery.
Jeff Hiller
Hi Garrett,
4 years ago
17 août 2020, 14:44 UTC−4
Thats what i figured I might have to do. Thanks for confirming it!
Spinoff: if I decided to model the "imaginary" 2.5 mm of nylon on each side as an "imaginary" infinite distance of nylon, would there be some good way of modeling that in COMSOL or would I run into the same issue of eventually needing a boundary condition?
Jeff Hiller
COMSOL Employee
4 years ago
17 août 2020, 16:42 UTC−4
Updated:
4 years ago
17 août 2020, 17:12 UTC−4
If you cut your computational domain far enough from the central region where your heat sources are, you may be able to make the engineering simplifaction that the heat flux on those side faces is small enough (compared to how much heat is lost through the top surface) that it can be neglected and therefore use an insulation condition on those far sidewalls. Whether that's true when the nylon is 2.5mm thick, I cannot tell you.
Jeff Hiller
4 years ago
18 août 2020, 08:49 UTC−4
Thank you so much for your time and thoughts! I really appreciate it! I'll give it a go!
