Zero Determinant of stiffness matrix
I am trying to evaluate the conditioning of the stiffness matrix. My simulations work fine and seem to give good results. However, when I extract the stiffness matrix into Matlab using an assembly node and LiveLink, the determinant gives zero. Why does my simulation work fine, but the stiffness matrix seems non-invertible?
Thank you,
Alex
4 Replies Last Post 24 août 2020, 17:21 UTC−4
Posted: 4 years ago 11 août 2020, 17:35 UTC−4
If you are looking at the noneliminated stiffness matrix, this is expected, but not if you are looking at the eliminated version. What type pf physics and boundary conditions are involved?
Henrik Sönnerlind
COMSOL
Posted: 4 years ago 11 août 2020, 21:03 UTC−4
Hi Henrik,
Thank you for the reply. I tried looking at both the eliminated and full stiffness matrices and both give the same result.
I am using a General Form PDE that is the same physics as the MFH module to calculate the magnetic field of a superconductor. The boundary condition used is a Dirichlet condition to set the magnetic field at the domain boundary.
Cheers,
Alex
Hi Henrik, Thank you for the reply. I tried looking at both the eliminated and full stiffness matrices and both give the same result. I am using a General Form PDE that is the same physics as the MFH module to calculate the magnetic field of a superconductor. The boundary condition used is a Dirichlet condition to set the magnetic field at the domain boundary. Cheers, Alex
Posted: 4 years ago 12 août 2020, 05:38 UTC−4
Then it difficult to guess. With sufficient Dirichlet conditions, the eliminated matrix should be nonsingular. What are the sizes of the two matrices?
Henrik Sönnerlind
COMSOL
Posted: 4 years ago 24 août 2020, 17:21 UTC−4
It turns out that the stiffness matrix is singular in my case since we are taking the curl of the test functions in the weak formulation (not sure why this makes the matrix singular, but I read it in a few research papers). Therefore, you need to calculate the condition number of the addition of the stiffness matrix and the damping matrix in order to consider the time-dependence of the weak formulation.
Cheers,
Alex
Hello, It turns out that the stiffness matrix is singular in my case since we are taking the curl of the test functions in the weak formulation (not sure why this makes the matrix singular, but I read it in a few research papers). Therefore, you need to calculate the condition number of the addition of the stiffness matrix and the damping matrix in order to consider the time-dependence of the weak formulation. Cheers, Alex
