structural mechanics module
Hi COMSOL users,
I am new to COMSOL and I am using structural mechanics , plane strain with fluid structure interaction module.I followed the example in the model library and with repeated inspections my model set up looks alright.bBut it gives me 'undefined value found' error. I would really appreciate if someone could give me some tips to solve the problem.
Thank you,
Manohar
5 Replies Last Post 15 mars 2011, 17:15 UTC−4
Posted: 2 decades ago 6 août 2009, 19:06 UTC−4
I am having the same problem. When using integration coupling variables (for global destination, use for global equation) I get the same error. Why doesnt it say which value is not defined?
Posted: 2 decades ago 7 août 2009, 04:30 UTC−4
I think that the problem is due to the definition of the expression. Please check if the expression you try to integrate is correclty defined "inside" the domain. As example, if you ask comsol to calculate the exspression "u" in the point x0,y0, which is outside the domain, comsol returs the error "undefined value found"
I hope this may help you
Pasquale
Hi, I think that the problem is due to the definition of the expression. Please check if the expression you try to integrate is correclty defined "inside" the domain. As example, if you ask comsol to calculate the exspression "u" in the point x0,y0, which is outside the domain, comsol returs the error "undefined value found" I hope this may help you Good luck Pasquale
Posted: 2 decades ago 23 déc. 2009, 17:06 UTC−5
so then how to include those points inside the domain?
thanks.
Pasquale
so then how to include those points inside the domain? thanks. [QUOTE] Hi, I think that the problem is due to the definition of the expression. Please check if the expression you try to integrate is correclty defined "inside" the domain. As example, if you ask comsol to calculate the exspression "u" in the point x0,y0, which is outside the domain, comsol returs the error "undefined value found" I hope this may help you Good luck Pasquale [/QUOTE]
Eivind Sjøtun Simonsen
Posted: 1 decade ago 12 nov. 2010, 06:26 UTC−5
I'm having the same problem. It seems that the mesh creates points which should be at the boundary of my model, by is outside the model domain. The problem occurs when I attach perfectly matched layers to my model. Removing these, removes the problem, but then I don't get the result I'm after.
Posted: 1 decade ago 15 mars 2011, 17:15 UTC−4
I also come across this problem now. Have you guys known how to solve it? Can you share your method with me? Thx a lot!
