Thermal stress in resonant beams
Posted 1 mars 2012, 11:13 UTC−5 Studies & Solvers, Structural Mechanics Version 4.2 2 Replies
Hi All
I have tried to simulate the resonance frequency of a beam which contains some thermal stress. I do following:
1 3D -> Thermal stress (st) -> eigenfrequency
2 Make a beam and select material
3 Fix the two ends of the beam and set the strain reference temperature above the temperature of the simulated beam.
4 Compute the eigenfrequency
Then I get some resonance frequencies. However they are not different from the case where the strain reference temperature is equal to the temperature of the simulated beam.
If I then include geometric nonlinearity the resonance frequencies become dependent on the difference between strain reference temperature and the temperature of the simulated beam. The reason why I need to include geometrical nonlinerarity is not clear for me. I have been reading in the documents in the help function but I am still confused.
Can any one tell me why I need to include geometrical nonlinearity?
2 Replies Last Post 6 mars 2012, 14:26 UTC−5
