Building a domain within a Difference
Posted 27 févr. 2012, 11:15 UTC−5 Version 4.2a 1 Reply
I am trying to model thermocouples within a geometry, I have used the "Difference" tool to create holes within my geometry, however, the heat diffusion in the solid has "kinks" in the line graph at these points. I feel these should not occur, and that the temperature curve should be continuous, I am assuming that these are here because I have not specified what these holes in the geometry are, as the heat flow is hindered.
Essentially, what I am stuck with, is how to "fit"thermocouples into these holes, and treat them as a domain made of a solid material?
Many thanks for the help!!
R
R
1 Reply Last Post 28 févr. 2012, 01:12 UTC−5
