Robert Koslover
Certified Consultant
4 years ago
26 juil. 2020, 19:23 UTC−4
Updated:
4 years ago
26 juil. 2020, 19:24 UTC−4
First, some Caveats:
(1) I would have to see your specific model details and how you set it up to be sure of my answer, and
(2) I only do thermal models occasionally.
That said, I believe the answer to your question is yes. I.e., if you are modeling thermal phenomena and have two domains that adjoin with a common boundary, then the assumed thermal contact resistance would be zero at that boundary. Note that you can specify a non-zero thermal contact resistance at the boundary, if you wish to do so.
That said, I believe the answer to your question is *yes*. I.e., if you are modeling thermal phenomena and have two domains that adjoin with a common boundary, then the assumed thermal *contact* resistance would be zero at that boundary. Note that *you can specify a non-zero thermal contact resistance* at the boundary, if you wish to do so.
