Numerical solution of a highly nonlinear PDE and the absence of the soliton solution
Hello. I try to solve the fourth order stationary PDE equation:
for right trangle geometry.
Following the procedure here and introducing and I rewrite the equation for the simulation
This equation can be represented as a General form PDE for the variables u, P, and Q: Gamma1=(ux+Px+Qx+1/3(ux)^3+ux(uy)^2), uy+Qy+1/3(uy)^3+uy(ux)^2) and F1=0;
Gamma2=(ux,0) and F2=P;
Gamma3=(0,uy) and F3=Q,
where all coefficients are equal to 1.
The equation is supplemented by Dirichlet conditions on the boundaries u=0 and the second derivatives uxx=0, uyy=0 also. Of course also I can introduce Neumann conditions.
It is well-known that for some approximations the equation gives rise soliton solution similar to a solution of the nonlinear Schrodinger equation. However and this is my problem after the Comsol simulation I obtain an obvious trivial solution with u=0. How to avoid this numerical solution? Is it possible? Thank you in advance.
3 Replies Last Post 29 juin 2020, 13:11 UTC−4
Posted: 5 years ago 29 juin 2020, 09:17 UTC−4
Hello Yuriy,
You can influence which solution the solver goes towards by providing a suitable initial guess using the Initial Values node. The default Initial Values is zero, so if zero is a trivial solution and you don't override the default Initial Values, that's what the solver will find.
Jeff Hiller
Hello Yuriy, You can influence which solution the solver goes towards by providing a suitable initial guess using the Initial Values node. The default Initial Values is zero, so if zero is a trivial solution and you don't override the default Initial Values, that's what the solver will find. Best regards, Jeff
Posted: 5 years ago 29 juin 2020, 11:06 UTC−4
Hello Yuriy,
Many thanks for the reply. Sure, I have played with initial guesses (values) that are different from zero. Nevertheless, I again obtain the zero solution eventually. If I'm not mistaken I can use also an initial function instead of a numerical value, am I correct?
>Hello Yuriy, > >You can influence which solution the solver goes towards by providing a suitable initial guess using the Initial Values node. The default Initial Values is zero, so if zero is a trivial solution and you don't override the default Initial Values, that's what the solver will find. > >Best regards, > >Jeff Many thanks for the reply. Sure, I have played with initial guesses (values) that are different from zero. Nevertheless, I again obtain the zero solution eventually. If I'm not mistaken I can use also an initial function instead of a numerical value, am I correct?
Posted: 5 years ago 29 juin 2020, 13:11 UTC−4
Yes, you can provide a function for the initial guess.
Jeff.
Jeff Hiller
Yes, you can provide a function for the initial guess. Best, Jeff.
