Setting Boundary Condition for Transient Navier Stokes
Hi all!
SETTING BOUNDARY CONDITION FOR TRANSIENT NAVIER STOKES
I want to set a boundary (i.e. inlet) with constant flow rate of 1.11 m/s.
In "Constant" option, I have set
u_in = 1.11 [m/s]
However, I cannot get initial value with the solver. I need the initial value (at t=0) for the transient solver to begin.
In the second case, I tried setting the flow rate at
u0 = 1.11*(t[1/s])
The transient solver (i.e. BiCGStab) could give a solution but the velocity is increasing with time and this is not what I want.
Basically, my case is very simple. A step increase of constant magnitude (i.e. constant velocity). How should I set me boundary condition in order for the solver to be able to obtain constant inlet flow?
Please help me! Thank you very much!
1 Reply Last Post 15 janv. 2010, 02:50 UTC−5
Posted: 2 decades ago 15 janv. 2010, 02:50 UTC−5
if you want to study th step, I wouuld trie one of the "heaviside" functions to make a short but smooth step, this helps the solvers to follow the non-linearities
Good lukc
Hi if you want to study th step, I wouuld trie one of the "heaviside" functions to make a short but smooth step, this helps the solvers to follow the non-linearities Good lukc Ivar
