Material model settings
what is the reason for this problem? The variable is not compatible with the added variable of the same name: root.comp1.solid.alphap. -Reason: different sizes -Previous variable: root.comp1.solid.alphap1 root.comp1.solid.alphap2
1 Reply Last Post 10 juin 2020, 20:56 UTC−4
Posted: 5 years ago 10 juin 2020, 20:56 UTC−4
Is the problem that occurs when setting two identical Hyperelastic material
