Loft command for Matlab Livelink
Hello, I am bulding a 3D geometry with Matlab Livelink (and COMSOL 5.5). I would like to ask if there is a command for performing Loft operations. I could not find anything on the list of commands in the Programming Reference Manual (https://doc.comsol.com/5.4/doc/com.comsol.help.comsol/COMSOL_ProgrammingReferenceManual.pdf): it seems lofting cannot be perfomed with Matlab. Is this true? Thank you!
1 Reply Last Post 8 juin 2020, 09:19 UTC−4
Posted: 5 years ago 8 juin 2020, 09:19 UTC−4
Hello GS,
Lofting is a capability found in the optional add-on product called the Design Module. To check whether your license includes that product, go to File > Licensed and Used Products. If your license does include that product, you will be able to perform a lofting. I don't know off hand what the equivalent command is, but remember that you can always perform an operation in the GUI and save your model as a .m file to see what the command is.
Jeff Hiller
Hello GS, Lofting is a capability found in the optional add-on product called the [Design Module](https://www.comsol.com/design-module). To check whether your license includes that product, go to File > Licensed and Used Products. If your license does include that product, you will be able to perform a lofting. I don't know off hand what the equivalent command is, but remember that you can always perform an operation in the GUI and save your model as a .m file to see what the command is. Best regards, Jeff
