Using solver manager with multiple solutions
Posted 14 févr. 2012, 06:44 UTC−5 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 4.2a 0 Replies
Is it possible to run the solver first with just the flow field enabled and with parametric continuation on to let me step through the desired gas jet velocities, then to switch off the flow field solution and enable the concentration solution and have it pick up the stored flow fields? I guess it should be but I am not sure how to do this.
The obvious question - why not solve both together - my machine doesn't have enough RAM and also the coupling of the turbulent diffusivity and flow field in seems to cause some issues. It's happier to solve flow first then concentration.
Hello Robert Low
