Model Pdf Error in Model Library
I am getting an error while opening a pdf of a model in the model library. Error is the following: "Error: Subscript out of range.". And as it can be expected, the pdf is not opening.
I have searched the web and found that this erros is given when there is a "try to access an element of an array that was either greater than its ubound or lower than its lbound". I think there is something wrong with a line of code somewhere in the program. I don't know how to solve this problem.
I use Comsol 4.2a. Following info will not help much but there is no C++ or any relevant coding program is installed in my computer.
Thank you,
Serhat
0 Replies Last Post 6 févr. 2012, 12:17 UTC−5
Hello Serhat Can
