2 févr. 2012, 04:25 UTC−5
COMSOL is slightly complex and confusing when you start, this is because of all the possibilities of all sorts of physics.
First you must become familiar with the COMSOL approach and notation, distinguis variables, their scope, the implicit notation of filds etc. There sre several interesting videos on the main site and numerous models in the model library.
my advice start with a few videos about comsol ,then about HT (heat transfer9 and do several of the simple exercicies, before starting the complex one with several physics. Once you are aquinted with the COMSOL methodology you can easily set up quite complex systems, you will soon see ;)
15 févr. 2012, 08:33 UTC−5
The problem is with the displacement os the heat flow, Idon't know how to make the heat flow moves over a surface.
Thank you
Thank you
15 févr. 2012, 09:08 UTC−5
when you define a BC (i.e. heat flux one) you select the boundaries where it applies, and you give a value. If this is a numerical value or a constant then the overall boundary gets this value, but you can aslo define a function of (x,y,z,t) (or r in 2D-axi, or a few only of all these). i.e. you can write q = 12[W/m^2*K]*(X-X0)/Length where X is the X coordinate, X0 an origine you decide and Length the total length over which you define your slope/gradient. then the heat flux will vary along the X direction. You do the same for Y,Z, R and or the time t
Just note that "x" and "X" are not always the same (upper and lower case) this depends on which frame you refer to (typically the spatial or material frame and if these are different, as for "solid" physics) and the different physics will/might give different links to the original or to the final deformed structure
