Exporting data files after parametric sweep with varying mesh size
Posted 27 avr. 2020, 08:22 UTC−4 Mesh, Results & Visualization Version 5.4 1 Reply
[start here] Hi, I'm doing a parametric sweep on some of my model's geometry parameters. I would like to export the data for each parameter combination into an independent .txt file for post-processing. I followed the instructions in the above discussion, but I get the following error:
"Data can only be exported if the same mesh is used for all parameter value"
Is there any way to do this? If I run the sweep and then save the results for each solution manually it works fine, but this is very tedious when I need to run many combinations...
Thank, Ori
Hello Ori Golani
