Error in Comsol 3.5a
I am currently trying to model an absorption column. However, I am coming across an error
Failed to evaluate variable.
-Variable: c
-Geometry: 1
-Subdomain: 1
- Expression: c
I am assuming this is an error due to my lack of experience with the program and any help would be appreciated.
1 Reply Last Post 29 janv. 2012, 02:45 UTC−5
Posted: 1 decade ago 29 janv. 2012, 02:45 UTC−5
The variable "c" is nomally the name of the COMSOL internal variable for the concetration of a species, either you have used it for your own variable name (then I would have expected a duplicate variable name error), or it could be that for your (sub-)domain 1 the variable c concentration is not or wrongly defined (no value, error in the equation.
Thats my best guess. "Re-"check all BC and physics values for (sub-)domain 1 you will probably find something ;)
Hi The variable "c" is nomally the name of the COMSOL internal variable for the concetration of a species, either you have used it for your own variable name (then I would have expected a duplicate variable name error), or it could be that for your (sub-)domain 1 the variable c concentration is not or wrongly defined (no value, error in the equation. Thats my best guess. "Re-"check all BC and physics values for (sub-)domain 1 you will probably find something ;) -- Good luck Ivar
