27 janv. 2012, 14:55 UTC−5
if you want a 3D "height" plot, you might need to export your data into an interpolation function (you might reimport it I beleive as a x,y Interpolation function and then use the GUI to plot it as a 2D XY plot with Y=t) or use Excel or matlab, as I'm not sure how to plot x,t like that (x,y is a standard 2D plot and there you can add a subnode "height")
Personally I plot 1D line plots "x" with multiple lines for such cases, never really tried what you are proposing
But I do certainly not know all the plotting tricks ;)
27 janv. 2012, 15:51 UTC−5
Thank you Ivar.
I want to ask the related problem. I got the solution c(x,t). And I want to get the value dc/dx at x=0 for all time.
I selected Result > Derived Values > Point Evaluation and Select the point x = 0.
And then I typed the Expression is : gradx_c
I got the Table Result, and it works.
My question is : Do we have another method to evaluate the dc/dx at x=0 ? Or the method proposed above is the only one ?
Thank you Ivar.
27 janv. 2012, 16:17 UTC−5
I've tried your method. Export the function c(x,t) as a txt file, and reimport the file in Comsol.
It works but not very good, it is hard in Comsol to change the the ratio of the axis. In my case, I got the 3D graph, but one axis is time (run from 0 to 1s) and one axis is distance (run from 0 to 20m). The graph is distort in one direction.
[QUOTE]
[/QUOTE]
27 janv. 2012, 18:19 UTC−5
if "c" is a dependent variable, there is a fair chance that COMSOL has already defined cx and cxx and ct ... (provided you have at least a 2nd order, or higher, shape function.
If not, there is a KB article about defining new equation to get more precise derivatives, its tailored for time derivatives, but why not also space derivatives, incase the firs hint is not possible.
Unfortnately I'm not by my COMSOL WS tonight ;)
