My owen expression
I would ask if I can add my expressions to the results (calculation of centripetal forces ...)?
Thank you.
1 Reply Last Post 25 janv. 2012, 11:16 UTC−5
Posted: 1 decade ago 25 janv. 2012, 11:16 UTC−5
take a look at the Results Derived Variable, here xyou can set in expressions and get the results in tables, and then plot from there, check the doc
Hi take a look at the Results Derived Variable, here xyou can set in expressions and get the results in tables, and then plot from there, check the doc -- Good luck Ivar
